MtnArch
"Cirque de Home Depot"?
The blue labeled conductor should be where the white is now and the white should be on an isolated bus bar. An equipment ground should have been pulled with the feeder.TheCommish said:i am not an electrican nor do I do electrical inspections, but it seems to me the white taped conductor should be where the blue one is.
I'd bet they strung the bottom of the joists before they started laying the insulation.globe trekker said:What's going to hold the insulation in place for years, ..eeerrr, hours, to come?
While strings may work well for insulation, they ain't much for plumbing. Are you suggesting that the plumber was satisfied with the temporary strings?ICE said:They are needlessly stringing this job along.![]()
Did you say "rotating knives?"ICE said:Carnival inspection. The slide is covered with Plexiglas that is coming apart. The hole is a perfect size and shape to remove a hand.
I think I saw that once in a movie ....ICE said:The man on top is beating the overhang apart with a sledge hammer.
i saw it in a bugs bunny cartoon or was it the roadrunner and wiley coyote?GBrackins said:I think I saw that once in a movie ....
The enclosure is attached to the building. As such, it must be built just like any other addition.steveray said:Back to the water heater....besides B-vent clearance, the PVC discharge pipe, and maybe combustion air (although I can't imagine it being built that tight...)....What else is wrong?
