Whether this is required or not depends on the insulation value of the insulation provided with the heater.Span said:I believe it also need to have insulation wrap around storage tank.
It's the live amo that gets them going.pwood said:What's a few spent shells anyway?
When I was a kid framing with my weed-challenged cousin, he enjoyed taking the duds and hammering them into the windows sills. Well, enjoyed it until one blew his hammer head off and broke his nose.ICE said:It's the live amo that gets them going.
That was my guess as well. It's like it is set up waiting for the welder. It has been there for years.Darren Emery said:On the tread picture - is that a friction set screw???
That's a beautiful stairway! Won't be nearly as pretty after they make it code compliant.ICE said:I am still looking for a house to buy and came across this:View attachment 1953
The picture is from Redfin. It appears that there is no guard rail At the second floor. I sent a copy of the picture to the local building dept.
No Alan I didn't. It is next to impossible to sell a house to a building inspector.MtnArch said:So, ICE, did you put an offer in on it?
This is not the required egress door so if there are two or fewer risers and the door does not swing over the stairs, no landing is required.fireguy said:Isn't the first step to be considered a landing? As a landing, isn't there a minimum depth?
I've never seen a 2x6 even close to that long! You should have asked him where in the world, he found such an animal. Not that it really matters, considering there so many other problems, but...ICE said:An attic storage/playroom space has been created in garage. The floor joists are 2x6. The span is 29'5". I could not find a splice in the floor joists. It would take a 30' 2x6 to pull that off. I wouldn't believe it if I hadn't seen it myself.
ICE said:An attic storage/playroom space has been created in garage. The floor joists are 2x6. The span is 29'5". I could not find a splice in the floor joists. It would take a 30' 2x6 to pull that off. I wouldn't believe it if I hadn't seen it myself. View attachment 2017
In the attic space there is a 2x hung from the ridge. The 2x is then nailed to the vertical 2x. The vertical 2x is toe nailed to a flat 2x that rests on the top of the 2x6 floor joists. The flat 2x is face nailed to the top of the floor joists. This took place at the mid-span of the floor joists.
The attic is accessed by a drop down stairs. I was told that the kids use it during the winter when it cools down. The owner is a fireman.
