my250r11
Sawhorse
Are those generic plans pulled off some web site??
Seems like
Not to many measurements
Bad labeling
Could be, too many variables to answer that, just assuming that is what the AHJ approved for the permit.
Seems like
Bad labeling
The bottom row of bricks is like a soldier course. The bricks appear to be the full 4" thickness of the brick wythe. It's odd, and an expensive way to compensate for an out-of-level footing, but I don't see anything that would scare me structurally for a residence.
It is true that bricks are stronger with the cores vertical, but residential foundations seldom load bricks to even 10% of their capacity.
Francis, cda, and my250r11......many thanks for your comments. The engineer called back about an hour ago. He said the foundation was "unconventional" at best. . I will post a few more pictures links. I wish I were better at that.
That is one of the major considerations CDA. I know a great home inspector who would probably find this quickly as it is only a few inches under the ground. The neighbor across the street knows about this foundation .. and he knows everybody else in the neighborhood...would I have to disclose this upon sale and how would that go over? Would it hold up as well as full length bricks on block upon a level footing? Should I be getting a new foundation or a modified foundation to conform to an irregular footing. Its a big problem for me. If there is any risk I don't want it. Whats in it for me?I am guessing you will not sell this house, but if you do will a good inspector find problems with the foundation.???
Yes, I have thought about that.I agree with cda....you'll not be able to sell the house. The work that's been done so far looks awful. I shudder to think what the rest of the building will look like.
I hate to say it this way, but if it passes all city inspection and you live in it,,, kind of well it has been blessed and I am guessing it will sell. Do you have to disclose anything, I am thinking no, because it passed,
Now if a good inspector looks at the house they might advise thier client to pass.
I have a problem with the design. Building on a stack of bricks is something that I have not seen before.
bhale7wv.....Thanks for you're input. I appreciate it. I'm trying to rapidly satisfy my concerns and I've made good progress. The last step is the structural engineer inspection which I have requested. All things usually work out. I will post how it goes. Thanks again. BuckBuck - not to worry - the brick laid on edge are just to get the masonry courses to the correct level. The load will be distributed evenly along the length of the wall, so these few brick on edge will not weaken the wall.
Your designer may be guilty of a little over-kill on the rods, but I assume that you are in a hurricane prone area & he just wants to make sure that if the house starts to blow away, it will take the foundation with it.
Am I alone in this thinking? The drawing that was provided is a wall section detail so there might be more to the foundation story but apparently re-bar is not included. The airgap between the CMU and brick is huge and the wire reinforcement that was maybe supposed to be a brick tie looks out of place. There's no way that a building would be on top of that here in Ca. .... well maybe a hundred years ago but then we started having earthquakes and changed it up.I have a problem with the design. Building on a stack of bricks is something that I have not seen before.
Haven't heard from Brent in a while.
