steveray
20 minutes with a big excavator.....
Yes, that is a good point.= & = & =
Not too difficult at all !..........How expensive would it be is
another story !
Also, ...who determines the "good workmanship manner" ?
Sorry CDA...I see now that you have asked this before. Slabs are very common here, and raised slabs are quite common. However, mine is raised more than normal... to 28"...to conform with other homes on the street which have crawl spaces. This makes my foundation a bit out of the ordinary but not much so...really nothing that presents a big challenge. Truckloads of sand will be placed in the foundation walls and will have to be compacted prior to the slab pour. According to the engineer, 12" of fill should be compacted down to 10" ....then another 12" of fill compacted down to 10". and so on in those stages....and then he added, "but nobody does that."Is this a normal foundation design for your area????
I don't know how the footing has been constructed so I can't say if it needs to be removed. Everything above it appears to be worthy of removal.
The footing is an unknown. Considering the work that we can see, there may not be any steel. Of course I am not familiar with the requirements in your locale and from what I can tell those requirements are less than what I would expect. Assuming that the footing is sufficient it can be saved.
There is plenty I could say but you need to reach that conclusion on your own.
Many thanks Conarb for your sound advice. I will take it seriously.Buck:
I have hesitated to comment on your situation because our California codes and standards are so much higher, but at this point I would ask if your state has a contractors' license board? I've volunteered as both an industry expert and arbitrator on cases here, many times work can be code compliant yet it doesn't meet industry standards, I've been assigned to write reports addressing industry and minimum workmanship standards, if you have a license board I'd file a complaint. Just to give you an idea here is one of my foundations.View attachment 2348
LOL, there's nothing heavy about that rebar mat. A bank fault probably has about 6 or 8 layers of bars spaced at about 6"! It certainly heavier than what you we see in a residential situation in most places but California is much different than most places.Your photo looks like it could possibly be a bank vault. Very good work.
So keep us up to date
Show us the fill
Show us the floor forms
Show us the poured floor
Buck:Got an e-mail asking to please put in writing why the foundation is not acceptable.
Show him the pictures.Got an e-mail asking to please put in writing why the foundation is not acceptable.
Conarb Thank you for the reply. I did hire an engineer but have not gotten a written report back yet. He did tell me that the workmanship was not good and that the foundation was not "conventional". One of my big concerns was the small cut down blocks supporting the brick structural wall. He thought this to be acceptable but agreed that it did not represent note AA on the plans. At this point I am afraid to state the name of my town on the web for fear of litigation against me. This is a very tight coastal community and my two year residence here carries little influence. That they now want something in writing from me is troublesome. I wanted a standard well built foundation but as you say, workmanship standards are different in differing areas.Buck:
Workmanship standards are different in differing areas, even differing areas within a state, you need to hire an engineer in your area to evaluate it and write a report. As I recall you are in North Carolina? If so which city? If you don't have a local source perhaps I can give you a name, if he's out of your area perhaps he knows one who is.
