By focusing on the technical cause of the collapse I suggest that we are missing the bigger picture.
Yes there was deterioration but the ultimate cause of the collapse was that the building management/owners, even after being told that there were problems, failed to do anything to address the problems .
Stupidity is a fatal disease.
If the foundation is rotten I fail to understand how that could be repaired without starting over.Well
There may have been a slight money issue.
One reason I am not into being part of a HOA, or condo type setting.
Each owner has to pay a portion, normally, and they may not have the money.
Champlain Towers South. Property owners were preparing to contribute their part in more than $9 million in projects.
I keep hearing different total units, from 136 up.
9 million dollars divided by 136…. Do the math.
Some people may not have the money
LA County has a similar problem with condo towers at Marina Del Rey
Exclusive: County Orders Inspection Of Marina City Club Towers In Marina Del Rey After Tragic Florida Condo Collapse
Los Angeles County officials have ordered an inspection of the Marina City Club Towers, a condominium complex with three buildings in Marina Del Rey, after the tragic Champlain Tower collapse in Florida last week.losangeles.cbslocal.com
Interesting read. The owner/builder modified the design, and fired the contractors who refused to build it his way. When cracks started appearing he refused to close the store because he wanted the revenue from the shoppers … but he and his executives did evacuate.I remember a building in South Korea that suffered a punch-through collapse. The cause of that one is pretty easy to see.
https://en.wikipedia.org/wiki/Sampoong_Department_Store_collapse
Theoretically, rents reflect the cost of operating the buildings. When a tenant leaves the new tenant pays the higher rent. Also, commercial building usually have a CAM clause, and the building manager is not shy about effecting repairs to preserve the owners asset. At least for commercial buildings that stay in desirable condition.Why not rental properties? Why not office buildings?
I think it is obvious that engineers will be the ones to make the call when a building is structurally unsound unless it is already obvious such as a partial collapse and then engineers will be needed to determine if a building can be shored up and then repaired or needs to be razed. I have had this situation multiple times and each time I called out an engineering firm for an evaluation and guidance as I am not an expert.Just because there are foundation issues, and there is no proof that they were the cause at the towers, you do not need to tear the building down. This is why you need engineers.
We will need to balance the heightened concern with the real risk. Why are people only concerned with condominiums? Why not rental properties? Why not office buildings? Why not tear down all buildings over 40 years old?
Yes there are issues but we should not respond in a hysterical manner.
Just heard this morning that they suspended all search and rescue operations because of concern that there may be additional collapse.From some of your posted photos, I'm not so sure there should be humans staging where they are under other areas of the condo. If there was a possibility of movement, additional areas may need secured? I understand you have to get in there and move material, but without knowing the reason for the collapse, caution should prevail in some areas I would think.
Yes, they quit recovery efforts for about 15 hours after they discovered that 1 of the columns that have not yet collapsed and shifted between 6 and 12 inches. Work resumed this afternoon however.Just heard this morning that they suspended all search and rescue operations because of concern that there may be additional collapse.
I read elsewhere that the builder is no longer in existence but I'm not sure about the firm or the principles.Is the firm or its principles still around, no word from any of them or the builder yet?
I wondered about from the beginning.Just heard this morning that they suspended all search and rescue operations because of concern that there may be additional collapse.
