Where/how did you get that information?The Photo is taken months after, you can see some of the regrowth on the trees
Soot, ash and debris have been cleared from around the structure and the road to it.
and as I stated See Post above RE: Chapter 7A, which is the structure protection.
Sprinklers protect the people
I got it from Google Photos, not from the video. I searched for Fire Sprinklered buildings in wild fire areas. Woop Woop….Where/how did you get that information?
The photo is taken from an NFPA video that discusses the importance of maintaining combustibles away from the home.
Not about feeling better. The information and evidence that you gave to support your claim was false. The home pictured is most likely not protected by a fire sprinkler system, and even if it is, had no impact on protecting the home from the forest fire.I got it from Google Photos, not from the video. I searched for Fire Sprinklered buildings in wild fire areas. Woop Woop….
I never said it was the current fire series
I also said with "Chapter 7A, which is the structure protection."
Do you feel better now. nothing is different.
Obviously you did not read the post relating to Chapter 7ANot about feeling better. The information and evidence that you gave to support your claim was false. The home pictured is most likely not protected by a fire sprinkler system, and even if it is, had no impact on protecting the home from the forest fire.
The structure pictured and being discussed survived because of good property maintenance, which is something the building codes for the most part do not and should not regulate. If you build in a fire prone or susceptible area, then it is necessary to keep trees and shrubbery away from the home. Keep gutters and roof clear, pine needles cleaned up, etc. Use of buffer zones is hugely important. Even a typical underground irrigation sprinkler system and landscaping can be a fundamental part of a buffer zone.
Conarb, how far back would you go to get the minimum health and safety standards, it wouldn't be the I-codes?
Is this supposed to be where I live, because I'm not Ty J. Lathrop of Bothell
I read it, but we do not have your Chapter 7A requirements.Obviously you did not read the post relating to Chapter 7A
Obviously you do not know what an example is.
I find it interesting where the word "reasonable" was added to the intent of the code. At some point a code provision could be determined by the courts as unreasonable based on any number of findings changing or empirical data.
Example: Energy code requirements that do not contribute to the overall performance of the house. Example all the mandatory air sealing requirements that are not enforced or installed in this state yet the homes are achieving a blower door test of 2.8 to 3.4 ACH and the state maximum is 4 ACH. If you meet the blower door test then the rest of the mandatory requirements could be found to be an unreasonable cost and requirement to the builder and homeowner.
2012 IBC
[A] 101.3 Intent.
The purpose of this code is to establish the minimum requirements to safeguard the public health, safety and general welfare through structural strength, means of egress facilities, stability, sanitation, adequate light and ventilation, energy conservation, and safety to life and property from fire and other hazards attributed to the built environment and to provide safety to fire fighters and emergency responders during emergency operations.
2018 IBC
[A] 101.3 Intent.
The purpose of this code is to establish the minimum requirements to provide a reasonable level of safety, public health and general welfare through structural strength, means of egress facilities, stability, sanitation, adequate light and ventilation, energy conservation, and safety to life and property from fire, explosion and other hazards, and to provide a reasonable level of safety to fire fighters and emergency responders during emergency operations.
Our government was founded and operated for over 100 years by decisions based on "reason". Today we hear "compromise" is what is needed to get things done in government at all levels. However it seems to be emotions and pre-conceived beliefs are what guides most people today. I believe the code development process is falling into that same mindset. Numbers used to justify a code proposal can be large, emotional and horrifying when taken as presented but turn them into percentages and they can quickly become a minuscule amount. We all hear about "follow the money" when you want to know the truth or motive behind something political or criminal. The same can be applied to code development. Is the proposal to get a specific product into the code such as locking caps on refrigeration systems or the intent of the code proposal for "safety to life" such as CO detection in residential homes.
All the codes are there for a reason, you may not understand why, I may not understand why, but they do have a reason.
- Tell the families of the dead and missing or the recent wild fires why Sprinkler codes should be elininated from the codes, so more willburn in their homes...
- Tell the people caught in the polar vortex why the energy code should be eliminated so more will die in their homes, and have heating bills they cannot pay.
- Not a code issue but a cost issue: tell me why a contractor charges 10,000 more for making the walls of a new restroom 8 feet instead of 5 feet for a accessible restroom?
Mark..I'll call BS on part of that....Sprinklers (likely) won't save you from a wildfire....
The energy code(s) have not saved a single life since they've been in existence. Not a single one. Prove your work, or that's just a made up talking point. I'll give you that some people die every year when it is very hot or very cold - but any energy code anyone has ever adopted wouldn't have saved even one of those lives.[/QUOTE
You need to ask anyone that lost the life of a loved one in the in the continuing to get worst storms or wildfires that are caused by climate change. (only 99% of scientists believe the world is round too)
Did the plumbing or mechanical code ever save anyone's lives? If they don't should we get rid of them?
Also there are a lot of things in the building code that don't save lives, like the required space in front of a toilet.
The less than 1% that sprinklers save vs. smoke detectors won't even hold up statistically - it's within the margin of error that that part of 1% even exists.
An 8 foot bathroom could easily add 10K to a bid over that 5 footer when you add architect fees, plan review fees, more architect fees, the cost of re-arranging the other areas in the space, etc. etc. It's not as cut-and-dried as contractors being dirtbags.
Just playing the devils advocate here. Dow Chemicals: Lets increase the R-values of residential construction so much that they have no choice but to use our spray foam and rigid foam plastics (plastic=petroleum=$$$) So that we can keep churning out more more more plastic and continue destroying the planet in the name of energy efficiency. Makes sense to me.The issue with energy efficiency being a "life safety" code is that it is not the clear cause and effect relationship that we are used of. When someone is required to install a smoke alarm, it could save their life. When people are required to build more energy efficient buildings, coupled with more fuel efficient cars, reduction in industry emissions, we start to see less carbon dioxide in the atmosphere. This in turn prevents deaths from related illnesses; lung cancer, heart attacks or respiratory diseases. Fundamentally, this is no different than radon gas, VOCs, or other long term health hazards.
yes, with CA amendmentsDoes CA use the International Wildland-Urban Interface Code or do they have their own code??
Cannot prove that, nor can they prove Seat belts save lives. Some that use them live, some die; some that don't use them live, some die. But fatalities appear less....The less than 1% that sprinklers save vs. smoke detectors won't even hold up statistically - it's within the margin of error that that part of 1% even exists.
Absolutely. But on the other side, the utility companies are making more money. Either way you make that argument someone is making money. The only difference is in adding more insulation Dow makes less than the utility companies would over time, meaning the building owner has saved money.Just playing the devils advocate here. Dow Chemicals: Lets increase the R-values of residential construction so much that they have no choice but to use our spray foam and rigid foam plastics (plastic=petroleum=$$$) So that we can keep churning out more more more plastic and continue destroying the planet in the name of energy efficiency. Makes sense to me.
