Yankee
There is NO GYP behind the panel! if they had made a recessed gyp nook it would comply! Are there no takers on the gypboard closet idea? A I corret in thinking there is nothing against putting the panels "in" the wall as long as the "inside" of the wall is gyp and/or 20 min door? (And , this is the "solution" given to me to make a decision upon), The underground entrance cable is not long enough to bump this mess out another 5 or 6 inches.north star said:& = &Since we have a non-compliant elec. panel install, ...lets ask
the design professionals on here what they would design /
recommend as a fix.
1. Remove the gypsum board behind the panelboard and
fill the cavity / areas with rock wool,
2. Remove the elec. panel itself and install it in a compliant
location [ this might be the least politically acceptable option ],
3. Remove the gypsum board behind the panelboard and box it
in and seal it with a layer of gypsum [ 1/2" min. ],
4. Remove the gypsum board behind the panelboard and
apply some type of [ actual ] fire rated product / coating
on to the back on the panelboard [ i.e. - a very large putty
pad, ...fire rated ceramic paint, ...other ],
5. other ?
What say ye design professionals out there ?
Also, ...since this is an electrical issue, what have you
electricians done in the past or present, for compliance
with one of these sit-chee-ay-shuns ?
Thanks!
