Existing Building Code | Stairs
subquestion: can there even be a shared exit without at least a little bit of shared corridor ?
CORRIDOR. An enclosed exit access component that defines and provides a path of egress travel.
From the IBC Commentary, in Chapter 2: Definitions:
And here's the above diagram, modified to show how you can have multiple tenants with direct exits, without any corridors. It doesn't have to be a 2-story building, either. This can be any number of stories if you introduce an elevator with a shared lobby near the center of the building.
Indeed !
Sooooo... what is your vote ?
quick survey... how do you read this verbiage ?
IEBC '21
804.1
- The requirements of this section shall be limited to work areas that include
exits or corridors shared by more than one tenant within the work area in which Level 2 alterations are being performed, and where specified they shall apply throughout the floor on which the work areas are located or otherwise beyond the work area.
