Yes, the code says that the foundation wall AND permanent supports must extend below the frost depth. I do not see the word OR in that sentence.imhotep said:Isn't a footing (if present) the permanent support for a foundation wall?
It would probably be easier and faster to amend your own AHJ's requirements, ratherthan go through "The Cow'" CMP's."They need to change the verbiage of the code then.................. "
NO, the foundation wall must extend below the frost depth. Does not mean the entire wall, just that it must extend below the frost depth.Pcinspector1 said:codeworks, I understand the building practice you have posted. The word in question is "FOUNDATION". The foundation must be below the frost line, let's say 24". At what point does the foundation below a frost line change to allow a wall design that you indicte to be built. On a basement foundation wall below a frost line at some point extends past the frost line to daylight for you to install a floor and wood wall as you have dipicted? Foundation verbage change needed or a better explaination.
pc1
There is a difference between Foundation and Foundation Wall. It specifically says that the Foundation Wall must extend below the frost depth. The Foundation Wall sits on top of the Footer.Yankee said:This is a good example of why it is helpful to know the intent of the code. Being stuck on the word "foundation" as opposed to understanding the guiding principle of the requirement
I don't agree with your cheap shot opinion but it is your opinion and you are entitled to it. Nothing says foundation wall system, it says foundation wall. There are footers and there are walls.mn joe said:Jar, that's a cheap shot. I expected better from you. I consider the walls and the footings to be part of a foundation wall system. You take the wording of "foundation wall" more literally. That is an administrative call that any B.O. is entitled to make. My interpretation is no more right or wrong than yours. I enforce the code properly according to the way I read it, as do you.Joe
While I agree that our codes can use improvements, the word "FOOTER" is not used in any of the codes I have. Which code section is it used in your codes, Jeff?jar546 said:It does not matter what is "customary" in your area if you have adopted the codebook as written. It says what it says.
