RickAstoria
- Joined
- Oct 17, 2009
- Messages
- 531
Re: Home Depot Crew
You have that authority to stop work because it is being performed in an unsafe manner. Not complying with OSHA is considered by LAW as "work being performed in an unsafe and dangerous manner". OSHA Regulations is the the regulation standard that defines safe occupational practices and how work is being performed safely.
Read Section 114 Stop Work Order (IBC 2009 -> Section 115)
Read Section 104.8 (In Oregon - review ORS 30.265) -> 104.8 Liability. See ORS 30.265 for regulations relating to liability.
Read 201.4
You have a responsibility to enforce / mandate OSHA compliance incidental to ensuring safety for you being able to perform your work. You may not enter a job site that will put your life at increased risk unless special circumstances require for inspecting a partially collapsed building for example. What does Section 114 say.
Stop Work Order:
114.1 Authority. Whenever the building official finds any
work regulated by this code being performed in a manner either
contrary to the provisions of this code or dangerous or unsafe,
the building official is authorized to issue a stop work order.
114.2 Issuance. The stop work order shall be in writing and shall
be given to the owner of the property involved, orto the owner's
agent, or to the person doing the work. Upon issuance of a stop
work order, the cited work shall immediately cease. The stop
work order shall state the reason for the order, and the conditions
under which the cited work will be permitted to resume.
114.3 Unlawful continuance. Any person who shall continue
any work after having been served with a stop work order,
except such work as that person is directed to perform to
remove a violation or unsafe condition, shall be subject to penalties
as prescribed by law.
Reason for Stop Work Order: Due to OSHA non-compliance creates an unsafe condition barring the code enforcement officer from being able to safely conduct code compliance inspection of construction work. Due to not being able to perform the code compliance inspection of construction work, there is potential code non-compliance. Therefore it is unsafe to allow construction work to continue.
Read this previous paragraph and think about the language. It probably can be improved but the point is - DUE to you not being able to perform your work in a safe environment to to non-OSHA compliance at work site. It puts you at unnecessary life-threatening risk. Since you may not perform your construction inspection for code compliance due to unsafe site conditions, you are issuing Stop Work Order due to potential non-code compliance and that it will endanger health, safety and welfare to allow construction to continue because code inspection for any code violation has not been performed.
You see how this can be done. Stop Work Order is because you can not perform the code inspection due to unsafe conditions such as unsafe work and dangerous work practices and non-OSHA compliance which places the site in a legally defined UNSAFE ENVIRONMENT. Due to not having completed the code inspection, there is potential risk of code violations that if construction is let to continue may not be resolved and potentially endanger the occupants in the future.
Work not being performed in a Non-OSHA compliant manner is "...work being performed in a unsafe or dangerous manner...".Uncle Bob said:Rick,And, all others that think that local building inspectors are required to enforce OSHA regulations, my part of this spitting contest; only refers to local building inspectors being required to enforce OSHA regulations; not, enforcement of adopted building codes.
Yes, we have regulations in the building codes that we enforce conserning saftey. My disagreement with Rick is that local building inspectors have no more authority to enforce OSHA regulations than a local cop has enforcing building codes.
The safety requirements of the codes are all we are charged with; not OSHA regulations.
Rick,
"You can issue a Stop Work Order and request things be brought into accordance with OSHA regulations and that an OSHA personnel has certified that it is compliant so that you may perform your work."
As a local building inspector; no, I can't! I cannot enforce OSHA regulations.
"YOU also have to follow OSHA regulations when inspecting."
No I don't; depending on what State I am working in;
"State and local government workers are excluded from Federal coverage under the Occupational Safety and Health Act of 1970 (the "OSH Act")."
http://www.osha.gov/dcsp/osp/public_sector.html
OSHA AND Federal ADA requirements are Federal laws and regulations enforced by Federal laws and regulators; not local building inspectors.
You keep stating that local Building Inspectors; not only have a legal right, but, a legal resposibility to enforce OSHA regulations; and that is not true.
Uncle Bob
Read 201.4
Stop Work Order:
