Re: REASONS FOR RESIDENTIAL SPRINKLERS
FM William Burns said:
incognito said:
3). Yes and on a yearly basis after install. Plan on $50.00 to $100.00 per year per dwelling.
(3) The installing standard and the code that references the standard do not require annual inspections or maintenance by any outside entity other than the owner of the system. (See IRC R313 and NFPA 13D 4.1.1 and A4.1.1)
I'm with Incognito on Item (3); I would expect the water district or health department to require a similar level of scrutiny to that currently practiced with BFP for lawn sprinkler systems, and require annual inspections.
As for Item (1), Washington State has a special sprinkler contractor license, but homeowners are exempt from work they perform in their own home. So, technically a homeowner could work on their own system (just like they can do their own electrical or plumbing, etc); where they get the parts, now that's another question.
On that note, in the case of Item (4), the hardware store should still carry PVC caps and glue, as well as 1/2-inch threaded brass plugs, so should you desire to "fix" your system, you could disable it for a pretty low cost.
jar546 said:
My next home will have a sprinkler system installed by choice. If I don't do it until 2011 then it will be installed as mandated by State adopted codes.
:? Then it's not a choice.
jar546 said:
Really, what's the big deal?
I am not looking forward to being required to have grab bars in every bathroom in my home and for stairs to no longer be permitted.
Based on the annual toll on human life, 1 in 3 over the age of 65 who will experience "a fall," something must be done to address the
cost of falls. Where is the public education campaign with a "Learn not to Fall" trailer informing people of the benefits of installing grab bars?
If an individual is more likely to be a victim of a fall than a victim of a fire, and we can keep even one more person from falling, wouldn't that be worth it?
Even if someone living in the home is not aged, an aged person could visit, or an aged person may be living there in the future. (This is similar to the NEC justification for the new mandate for tamper-resistant receptacles.)
Now that we've got sprinklers and grab bars, the next step, pardon the pun, is to eliminate stairs. Homes should be only one level or provided with elevator access or exterior grade access. Homes will be more expensive to build with an elevator? Well, that all depends on the jurisdiction, the type of elevator, plenty of room for debate on that. Besides, homes with elevators are more desirable, so it will actually increase the value of the home. (wait, this sounds eerily familiar!)
It's my freedom; it's a really big deal.
