The counter was over 188,000 when Jeff changed up the forum. It dropped to around 10,000 and since then there has been another 35,000. It should show 220,000 .... but who's counting.
Louvered door for combustion air?
I mentioned it to him but....Jeff's just like Subway, doing away with the stamps after you've collected a gillion!![]()
My mistake, I should have written “building sewer” which places it on private property.Interesting, our inspectors don't inspect sewers, they are inspected by the Sanitary District who pulls TV cameras through the sewer laterals and mains.
Conarb, Do they allow storm water in the sewer laterals or is that taboo in your area!
We do not want storm water infiltration into or sanitary sewer lines here.
I inspect utility laterals as well. Water, storm, and sewer before back-fill.
If that hub is the type I'm thinking it is it isn't approved for outdoor usage. There is no means for sealing it to the box it is mounted on. It's just flat on the bottom, even if you put some type of sealant between the 2 flat surfaces it probably wouldn't seal well. They are only approved for interior usage and I believe some area study would approve them for that.
