Oh Well
There can’t be more than one wire in that lay-in lug.Is the ground wire clamp correct? Looks like the green wire is not under the screw very well.
The site plan shows two 600 gallon tanks. There's no description of the tanks or any details. I found the leaders and drain pipe. The idea is to take the water from roof drains and put it in the tanks.
Neither tank has been placed per plan. That's because they would have been in/under the driveway and there's already water pipe, building sewer pipe, gas pipe and conduit under the driveway.
The six inch schedule 40 has no cleanouts and none are shown on the plan. There is no provision for draining the tanks once they are full except for the fact that the inlet and outlet are at the same level. The purpose of the tank is for irrigation. The tanks will fill with rain water and then in the summer the water can be used for irrigation.
The main house is 12,000 sq.ft. There are two other houses....one for the pool and one for whatever. An artisan was brought from Hawaii to decorate the bottom of the pool. There is extensive landscape planned with irrigation. ......and somebody thought it was a good idea to make them install these tanks that couldn't be used if they wanted to.
That would not be legal.Did you allow the Siemens breaker in the Eaton BR, "Zinsco II" panel, going into UL listed, vs classified quagmire, not seen anything allowing Siemens QP, or it's lookalike cousin Murray MP, to be installed in any competitive panel.
NoWouldn't the tanks need straps to prevent floating up?
They didn't use glue. I recommended that they remove entire sheets rather than cut open the the areas that have electrical. They decided to cut open rather than remove.Box depth and gap around the e-box, ...not good!
Do you think they used glue on the drywall or can they just back the screws out?
who would have approved that design a 3'6" can side support an 8' wall! Maybe they fully reinforce masonry fences in California? Footing for existing wall looks to be a sloping footing never seen that with masonry.
The first time that they open the lid on one of those tanks will be the last time.
It'll be new to them. A riser alone will not drain the tank.They make risers for those tanks to bring them to grade once they are buried. This is nothing new
Well the plans states there is an existing footing where obviously there is not because there I a pipe where there should be what appears to be calling out a continuous footing. Cant quit tell if that is a footing above the pipe or not. Either way that is a wall collapse waiting to happen.
what does the neighbor have to say?
At least your state has contractor license laws. But I wonder too if contractor license laws really make a difference.
