It's a bit early to push my red button, but here it goes.The inspector may conduct other inspections to ascertain compliance with the UCC or municipal ordinances.
The inspector shall conduct a final inspection of completed construction work.
Because you know how much I love to debate....Too lazy or too busy? FYI, we do not do a roof start or siding start nor sheathing inspections... .....So let's say I have 5 inspectors and we do 10,000 inspections a year doing the minimum inspections and we schedule about 2 weeks out...How do I incorporate more inspections? Go 3 weeks out? Convince the municipality to fund another inspector or 2? If I can't convince the municipality of the value of doing my job better (protecting lives and the grand list), I have no chance...They just keep us as a cash cow...Some people do their job and others look for excuses not to. Seriously, how lazy do people choose to be?
Which is illegal in all 50 states. You are suppose to be an enterprise fund.They just keep us as a cash cow.
So I have 3 guys that do 6500-7000 inspections per year along with plan review and that is more than manageable with an average inspection load of 9 inspections per day so your 10,000 between 5 inspectors is even more manageable, especially if they don't do plan review. That is based on 245 working days per year.So let's say I have 5 inspectors and we do 10,000 inspections a year doing the minimum inspections and we schedule about 2 weeks out
We all do plan review.....And it depends on what you call an inspection, how far you commute between, and a variety of other factors....So I have 3 guys that do 6500-7000 inspections per year along with plan review and that is more than manageable with an average inspection load of 9 inspections per day so your 10,000 between 5 inspectors is even more manageable, especially if they don't do plan review. That is based on 245 working days per year.
Lots of things are illegal....Does not mean they don't happen.....Which is illegal in all 50 states. You are suppose to be an enterprise fund.
You guys aren't counting correctly. I recently worked a day in a city with a population of 210,000. Five inspectors handled 243 inspections for that day....at least that was the story.So I have 3 guys that do 6500-7000 inspections per year along with plan review and that is more than manageable with an average inspection load of 9 inspections per day so your 10,000 between 5 inspectors is even more manageable, especially if they don't do plan review. That is based on 245 working days per year.
Every state has an attorney general to report toLots of things are illegal....Does not mean they don't happen.....
Sounds similar to what the grand jury found out about the Dade County building department after Hurricane AndrewFive inspectors handled 243 inspections for that day....at least that was the story.
Palm Beach County is 2,383 square miles. At one time, while working for a third-party agency doing inspections I would average 16 inspections a day and had as many as 26, throughout the entire county, especially when I covered the county school district so there were times when I had to go from the farthest southeast corner on the ocean to the northwestern most point on Lake Okeechobee. So averaging 8-9 inspections per day would be a breeze.9 inspections in 9 different locations can be unrealistic in a lot of jurisdictions depending on the travel distance between inspections.
Hendry county Fl is 1,100 sq miles. Sometimes an inspection would take 2 or 3 hours if it was in the southern end of the county.
And Surfside....and Ghostship....and......Sounds similar to what the grand jury found out about the Dade County building department after Hurricane Andrew
18 minutes per inspection. I can't do that. Sometimes it takes me 15 minutes just to get out of the truck and climb the 3 flights of stairs to get to what needs to be inspected.had as many as 26, throughout the entire county,
Locations is definitely more important than number of inspection. A bad day like 26 inspections (and rare) usually equates to about 12-16 locations, sometimes less. We had 11 roof inspections the other day that were all on the same building but separated parcels.I try to limit my inspectors to six locations a day.
Amen....Especially when there is a 3/4" stack or truss sheets....And all of the multiply connections are wrong.....Do you verify all the truss bracing required by the truss engineer has been installed? That is a very time-consuming inspection when done correctly.
That sounds about right for a fail rate.I wish I could easily report on it, but I bet we have a 30-40% failure rate....It's a lot faster when you can pass stuff...
80% herewe have a 30-40% failure rate
The inevitable thread drift is off of the horizon at this point.We're way off into the weeds.
