At least they didn't forget to install Valley flashing!Paul Sweet said:Valley flashing isn't always the right way.
It's always funny when they just don't understand the concept.Paul Sweet said:Valley flashing isn't always the right way.
While that's true the jurisdiction of the building code you are enforcing stops 5' from the permitted structure. In your AHJ don't you have a different department that inspects septic tanks? Don't you have a sanitary district that inspects sewers?ICE said:Our jurisdiction stops at the property line.
I didn't know about the five feet from the building.conarb said:While that's true the jurisdiction of the building code you are enforcing stops 5' from the permitted structure. In your AHJ don't you have a different department that inspects septic tanks? Don't you have a sanitary district that inspects sewers?
Am I my looking at those wrong or other form boards put up as if he is going to pour the entire backyard as a slab since the taller side of the forms are towards the hole? I guess I'm missing what he's trying to do.ICE said:Here's another contractor that can't conceptualize. I should put that on the correction notice. I could tell them that Brent made me do it.
The all-thread is supposed to be an HD anchor.
I worked on a Marriott hotel in Sacramento. It is multistory wood. There are huge anchors near the elevators. They are 6' long and 1.5" in diameter with large steel plates and jamb nuts. Well they came up short by several inches so the contractor un-threaded them....right out of those big steel plates and jamb nuts.
Yes Ma'am, you are looking at it wrong. It will be a raised foundation.Msradell said:Am I my looking at those wrong or other form boards put up as if he is going to pour the entire backyard as a slab since the taller side of the forms are towards the hole? I guess I'm missing what he's trying to do.
At least he was smart enough to know there should be a beam there. Right idea, ****-poor execution.ICE said:It is difficult to believe that a licensed contractor did this.There was a wall. It was a bearing wall supporting ceiling joists from two rooms.
There is now a pair of 2"x8" sitting on top of the spot where there was a wall.
The kickers are attached to the ceiling joist. The purlin brace might be all that holds up the 2"x8"s.
About half of a messed up furnace install is sitting on the joists.
You know what gets me about your pictures Tiger is that we are both in California, since the advent of the 1998 CBC we can't get a building department to approve anything without an engineer's stamp, all engineers want drilled pier and grade beam foundations, those piers go down a minimum of 5'. About that time I had to build an addition on a home and as usual the engineer designed a pier and grade beam foundation, I went to him making the argument that since the house was a "T Foundation" the addition should be the same because of differential settlement, I lost the argument because the engineer maintained that the T foundation under the home had been there for over 30 years and was done settling, you don't want to use a T under the addition since it will settle.\ said:There's quite a bit of work here. It looks pretty good. It's too damned bad that it has to come out. You see, they didn't see the detail that shows the footing 24" into undisturbed soul. So they are 16' to 18" deep.I have encountered this hundreds of times. Yes I said hundreds. It is because the detail is small and the writing is tiny and the info is nowhere else on the plans. Hell, sometimes I have to search for it. I have asked that there be a big warning on the foundation page. Apparently that would be too much trouble, but doing all of this work over is no big deal.
Ok then. New construction windows were installed. Trouble is they've only ever installed retrofit windows and have never done lath before now. The guy that is the boss is a Dandy. He makes it sound like he's been in business forever.ICE said:
