fatboy
Administrator
aaaa, how is it that the valley is cut in the wrong direction? Code section?
Installation instructions. The valley shall be cut from the high side or largest expanse.fatboy said:aaaa, how is it that the valley is cut in the wrong direction? Code section?
At least they didn't forget to install Valley flashing!Paul Sweet said:Valley flashing isn't always the right way.
It's always funny when they just don't understand the concept.Paul Sweet said:Valley flashing isn't always the right way.
While that's true the jurisdiction of the building code you are enforcing stops 5' from the permitted structure. In your AHJ don't you have a different department that inspects septic tanks? Don't you have a sanitary district that inspects sewers?ICE said:Our jurisdiction stops at the property line.
I didn't know about the five feet from the building.conarb said:While that's true the jurisdiction of the building code you are enforcing stops 5' from the permitted structure. In your AHJ don't you have a different department that inspects septic tanks? Don't you have a sanitary district that inspects sewers?
Am I my looking at those wrong or other form boards put up as if he is going to pour the entire backyard as a slab since the taller side of the forms are towards the hole? I guess I'm missing what he's trying to do.ICE said:Here's another contractor that can't conceptualize. I should put that on the correction notice. I could tell them that Brent made me do it.
The all-thread is supposed to be an HD anchor.
I worked on a Marriott hotel in Sacramento. It is multistory wood. There are huge anchors near the elevators. They are 6' long and 1.5" in diameter with large steel plates and jamb nuts. Well they came up short by several inches so the contractor un-threaded them....right out of those big steel plates and jamb nuts.
Yes Ma'am, you are looking at it wrong. It will be a raised foundation.Msradell said:Am I my looking at those wrong or other form boards put up as if he is going to pour the entire backyard as a slab since the taller side of the forms are towards the hole? I guess I'm missing what he's trying to do.
