Mr. Inspector
Why do you need rafter ties if the ceiling joists are attached to the rafters?
I see the ties at that location quite often. All those years ago, that was the way they did it. What, if any, value they provide is not for me to consider. When they are removed I ask for a replacement. In this case there is room above the furnace that will be close to the original location.Rick you are correct, the CJ's complete the tie but what is the 2x6 in the picture that's midway up? it's not a rafter tie unless its in the lower third of the attic space. And it's not a collar tie.
Are those shingles on the roof of the house next door? If so, the extended roof with almost flat and shingles certainly are not allowed there.
Outdoor receptacles must be equipped with an in use cover....laundry appliances are not listed for use in a wet location.Don't see very many washer and dryers out side, do the electrical connections need to be weatherproof? Yellow house behind the power pole. Maybe that's just an extra set?
They were doing the work without a permit and another inspector gave them a stop work order. It was done when I saw it for the first time. The owner asked me what I want him to do. I told him to follow the plan.Does not matter how much or what kind of paint the use that OSB will be gone in 5 to years. The moisture coming from the car wash will play a big role in it.
