So much for the required egress door...TheCommish said:So just before I went to the great concrete jungle for vacation, I was out for a scheduled solar array final. There was no answer at the accessible door and the permit was snug behind the snow and glass. I missed you tag left and on my way. By the time I got back to the office the owner had called, they had stepped out for a bit, can I come back, well has the electric inspection been done, oh no. Call the contractor and leave a message, get the electrical inspection done then reschedule, then maybe we will give you the signed interconnect agreement.Ice the white stuff is snow.
there is so much snow around here I would guess %50 of the front walks are not shoveled, not a problem if you don't have a storm door. Here in Massachusetts we require 2 egress doors, the second can be 32 inch clear and sliding. The trade off is the EERO from a bedroom with a double hung windows are allowed to be 3.3 square feetsteveray said:So much for the required egress door...
To start with it doesn't look like it's thick enough to be compliant with today's insulation standards. If it does meet current code I don't see any way that you can actually deny him the ability to use it. I just make sure that each piece had markings that show the R-value of it. If it isn't marked it can't be used!ICE said:This insulation came from an illegal addition that was torn down. That addition was from the 90's. Now a new addition has been built and they want to use the insulation again. It hasn't been wet. Would you allow them to reuse the insulation?
