Where did I make up a code like I said before I will not approve it.mark handler said:building inspectors, who make up their own codes?
Please read previous posts. The closet rule is a baseline. There are rooms with closets that obviously are not intended to be bedrooms.mark handler said:Is a storage space with a door a closet? Entry halls are by your definition a bedroom.Is a Pantry with a door a closet? Kitchens are by your definition a bedroom.
Mark, how about reading the thread before throwing out ignorant quips.mark handler said:Code section? Making up codes?
TimNY said:The County did away with the "label game", as people would have a den, a family room, a library, a media room, an office.. everything but bedrooms since more bedrooms == more septic.
righter101 said:I would be curious to see other jurisdications policies of "creation of a sleeping room", or definitions of bedroom.
We have this issue coming up all the time. The biggest reason for us, being a rural county, served by septic, the required septic design is based on the number of bedrooms. If you have a 3 bedroom design, you can not build or remodel your house to a condition that would have 4 bedrooms, without upgrading your septic system.
I missed the part where the IRC governed the design of septic systems, or how to determine the size of a septic system. I don't think that any authority regulating a septic system is required to be bound by the IRC definition of bedroom (whick, afaik, is NOT defined in the code).TimNY said:For the purposes of septic here, each home is allotted a kitchen, living room, dining room, foyer and another room such as "den", "study", "library" (whatever they want to call it), all other rooms are bedrooms. An unfinished basement is also exempt.
Thanks rktect. This thread has been fun.rktect 1 said:Just for fun.
"ignorant quips"TimNY said:Mark, how about reading the thread before throwing out ignorant quips.I have been nothing but respectful in all of my posts. Please read before posting the one-liners.
John,JBI said:Play nice boys... There is no code based arguement for relabeling of interior rooms or spaces by the AHJ. You can't control what people will do after the CofO is issued, pull up your big boy undies and deal with it. Buyers and real estate people are getting more savvy all the time and checking with the AHJ before buying/listing a home, and yes you will certainly catch more than a few violations through this process. Issuing a CofO is like setting a speed limit, you list everything you possibly can and hope people will do the right thing. IF YOU CATCH SOMEONE SPEEDING, THEN ISSUE THEM A TICKET. Until you catch them in violation, there is nothing to cite. Personally, if I had my plans turned down because of some 'policy' with no legitimate force of law behind it, your jurisdiction (possibly you personally) will be paying for my house and then some. Code Officials are not G-D, certification is not deification. If you can't cite a code section, don't try to enforce your personal opinion.
i seem to be agreeing with brudgers an awful lot lately... THAT's scary! LOL (just kidding Ben...)
Guest?....Bootleg said:.... BE MY GUESS.
Thank's Mark.mark handler said:Guest?....
The minimum system here is 4 bedrooms in most cases. When you get to wetlands and shallow pools they will approve a 3 bedroom simply because a 4 bedroom system will not fit.Robert Ellenberg said:One jurisdiction I built in solved the septic problem by setting the minium size system as what was needed for a 3 bedroom home--even if you called it a one bedroom cottage. If you showed more than 3, you put in a bigger system.
Mark,mark handler said:You don't see "ignorant quips" as disrespectful?Remember that. I will.
Yes, I do see your ignorant quips as disrespectful. My pointing them out is simply a matter of fact.mark handler said:You don't see "ignorant quips" as disrespectful?
R109.4 Approval required.JBI said:Personally, if I had my plans turned down because of some 'policy' with no legitimate force of law behind it, your jurisdiction (possibly you personally) will be paying for my house and then some. Code Officials are not G-D, certification is not deification. If you can't cite a code section, don't try to enforce your personal opinion. i seem to be agreeing with brudgers an awful lot lately... THAT's scary! LOL (just kidding Ben...)
Didn't realize what a hot topic this would turn out to be.Jobsaver said:Thanks rktect. This thread has been fun.
You can imagine, it is the number of people living in a home that determines the load, and probable use, of rooms having closable doors and closets. These are the rooms most likely to be used as sleeping rooms. They are, in my determination, the very type of room that the code refers to as sleeping rooms.Yankee said:As to the "septic system argument", my jurisdiction also used to count bedroom as rooms with closets and be diligent about checking that the number of bedrooms equaled the number approved on the septic plan. But in the end we realized that it didn't matter. The number of bedrooms doesn't equate to the actual load on the system (that is simply a design value). You can imagine, it is the number of people and the manner of use that causes the load. If homeowners overload their system and blow it out, they must build another.So counting bedrooms as those labeled does make sense, and encouraging all "closed door" spaces to have secondary means of escape also makes sense.
