Ah, to be or not to be. Are footings (footers) and foundations (over-sized stem walls) mutually exclusive? If you only have a foundation (i.e., grade beam), is there no footing? If you only have a footing (i.e., thickened slab), is there no foundation? Since footing is mentioned in the text, maybe it doesn't need frost-protection. Where is Rene Magritte when you need him?Mule said:Why can't thhe foundation wall be part of the footing?
Winner! Nice job GBrackins, now let's see what jar bounces back with.GBrackins said:Correct me if I am wrong (as if there was no chance of that here ...) but when I read Table R301.2(1) for Frost Line Depth it doesn't it say it subpart b "The jurisdiction shall fill in the frost line depth column with the minimum depth of footing below finish grade?" Doesn't this specify the depth of footing, or am I reading this incorrectly?
That is a partial drawing. Look at the bottom of the wall, it continuesMule said:Why can't thhe foundation wall be part of the footing?
Must EXTEND below the frost depth. Nothing says it has to be completely below frost depth.High Desert said:Mac, in that case the bottom of the wall would be the footing. Using jar's logic that entire wall would have to be below the frost line. Tough to build something on it when it's underground. I've only seen that type of construction done once in my 27 years of inspections. The wall would have to meet the width requirements for footings in Table R403.1 I believe.
