Oh Well
The wrap goes on as the siding goes on. Nobody would wrap the building and then start the siding.…especially with a two story. You just have to trust them for some things.
With the zipsystem, the siding guy puts on the counterflash to the stepflashing....Maybe....The wrap goes on as the siding goes on. Nobody would wrap the building and then start the siding.…especially with a two story. You just have to trust them for some things.
In your world.The wrap goes on as the siding goes on
They did not even have house wrap in those days. You had to use felt paper.I did a lot of siding and trim as a piece worker. T1-11, Masonite, cedar, redwood and chipboard. In every case we installed the flashing and wrap.
Tyvek was popular. Some years later siding was removed and found that the Tyvek was a powder. A week in the sun before the siding went on killed it. There was another wrap named Barricade; tough stuff it was but I preferred building paper. I could strip off a manageable roll and run with it.They did not even have house wrap in those days. You had to use felt paper.
Yep...Kickout flashing is a big failure item here....Bigger problem is the siding guy now "has to" cut down the I&W and properly counterflash this...And no one seems to understand down and out with flashing and I&W is not magic....
ICE, it all depends on what the local AHJ feels is the correct method.I did a lot of siding and trim as a piece worker. T1-11, Masonite, cedar, redwood and chipboard. In every case we installed the flashing and wrap.
When I was the guy doing the work I was in the Sacramento area. Most everything was siding and few were stucco. I installed the building paper at the same time as I installed the siding. When I became an inspector I was in Southern California and most everything is stucco so we do a lath inspection and that includes the building paper. Although it is rare, I do find the WRB done wrong... around windows or a single layer over sheathing and bucking water.It works with many an inspector that I still deal with today. the problem you had is the area you covered, 80% did not want to comply, 20% just figured it was simpler.
Every zip house I have seen is done this way....At least until we reinspect the ones in my TownWhen I took a closer look I realized that this is completely wrong. There is no 1"x4" or counter-flashing.
When is the counter-flashing installed and what supports it? Does the siding land on counter-flashing? Do you have a picture of the finished product?Every zip house I have seen is done this way....At least until we reinspect the ones in my Town
Man you Cali guys are picky. LOLWhen I took a closer look I realized that this is completely wrong. There is no 1"x4" or counter-flashing.
The siding guy tapes it....When is the counter-flashing installed and what supports it?
Sounds strange to rely on tape ... but hey now, if it works for you, who am I to judge? I would still like to see the procedure and the end product.The siding guy tapes it....
ICE, would you rely on "Superglue?" That guy and the hard hat being picked up!Sounds strange to rely on tape .
We won't until the lawsuits....Sounds strange to rely on tape ... but hey now, if it works for you, who am I to judge? I would still like to see the procedure and the end product.
Not here. Shiners can work their way out and cause a leak.Kinda important but theirs usually a shingled roof installed by the time the inspector shows to do the rough-in inspection.
