Rider Rick
- Joined
- Oct 19, 2009
- Messages
- 468
ICE, watch alot of youtube?
Why would I want to hook my furnace blower up. I have two 10KW electric furnaces and neither of my generators will pull them. I do like everyone who has one, I light the gas logs in the fireplace. If I didn’t have gas logs I would put on some cloths.gfretwell said:Jw, How did you "legally" hook up your furnace blower?
As well as a lot of unlisted ones.gfretwell said:I also wonder about what you say about "U/L requiring the neutral being bonded" since there are listed generators out there that don't. (some Hondas for example).
Of all the NRTLs out there they all use ULs Standards.gfretwell said:BTW U/L is only one of over a dozen NRTLs. I don't know what you do when they disagree.
I make all my decisions based on the adopted laws.gfretwell said:Perhaps you just look for the potential hazards and make your decision based on safety.
But is it not safer than the uninsulated conductor of the type NM cable? After all it was you that said one is safer than the other. I am the one who keeps saying that it is either code compliant or it is not.Builder Bob said:jwelectric........ The SJO cord has a heavier insulation than NM and would not allow the heat to dissipate as easily as NM cable, thus the rating difference in the types of insulators for #8 conductor....Next question?
You could not put enough on at 10 below for 5 to day days much less the damage that will be done to the home with the loss of heatIf I didn’t have gas logs I would put on some cloths
The original question was about a certain interlock kit.My post was addressing this question and the compliance of this kit and the type generator that is most commonly used.mtlogcabin said:You could not put enough on at 10 below for 5 to day days much less the damage that will be done to the home with the loss of heatI will shut off the main breaker and do what I need to do to provide heat for my family.
Smart manBuilder Bob said:smart _____ ... I bet you can fill in the blank.
Good grief,north star said:= + =In referring to the OP, ...at last count, I have 3 FOR using the interlock
kit, 1, possibly 2 AGAINST, and some did not state their choice......Are
we still voting? :devil
Can you produce a copy of your birth certificate?jwelectric said:I am not deaf and dumb I can talk and listen. First someone would have to answer some questions. I would use 110.3(B), 702.12, 250.34, 250.30, 225.31 and 225.36 as starters and depending on the type of installation I can continue. Oh by the way these would be sited on the inspection report instead of just saying this is what I want to see.
My name is not Obama so why do I need one?ICE said:Can you produce a copy of your birth certificate?
Argue with that....and then produce a birth certificate.steveray said:Exempt.....portable electric eqipment?Electrical:
Repairs and maintenance: A permit shall not be required for minor repair work, including the replacement of lamps or the connection of approved portable electrical equipment to approved permanently installed receptacles.
Geeze I didn't know that a permit would ensure a compliant installation, if it did we would need those code enforcement folks would we. Just what does a permit and code compliance have to do with each other? Have you lost your mind, wait you first have to have one before you can lose it.ICE said:Argue with that....and then produce a birth certificate.
