Well no I don't know that or why there are four clamps when two would suffice......if any of it made sense.Any idea what the valve that is dead headed just above ground level is for?
RV hook upThese are on the front of a house. I do not know what they are for. Do you?
They just wanted to make sure that the roof had sufficient slope. I didn't know which way to make it so they compromise and went both ways with it.
1) Rafter ties at 48" missingThe corrections came to me faster than I could write them down.
# 16 should have said secure the NM at 4.5 ft. intervals max....but alas and alak I forgot to write it.
The CSST mates up with the refrigerant lines and goes...where I don't know.
As I handed the lady homeowner the corretions, she asked me if any of them were the responsibility of the owner and not the contractor. She has experienced a number of my inspections related to an addition so she is used to hearing, "It's the inspector's whim and you will have to pay for it". So I showed her this picture and said "only one". When she heard the words molten copper I could see a google icon in her eye.
Tiger doesn't say but I assume the permit is to change out an attic furnace, can permittees really be forced to add insulation when getting a permit to change out a furnace?1) Rafter ties at 48" missing
2) Ceiling Insulation missing
3) Flue clearance to combustibles
4) Flue support missing
5) Furnace power supply by plug in cord
6) Electrical connections in last photo?
What else?
That's what i was assuming.The insulation is on the ceiling not the the roof, and just guessing but if the unit is in the garage then that is not conditioned space did not need insulation when the home was built.
I see the ties at that location quite often. All those years ago, that was the way they did it. What, if any, value they provide is not for me to consider. When they are removed I ask for a replacement. In this case there is room above the furnace that will be close to the original location.Rick you are correct, the CJ's complete the tie but what is the 2x6 in the picture that's midway up? it's not a rafter tie unless its in the lower third of the attic space. And it's not a collar tie.
