You should go into elementary education. Special ed.Then I had to tell him how..
I had to tell the contractor to use the water main as an electrode.
These are small closets with a furnace and maybe a condensate pump but nothing more.
Yes, all the way around ....the width of the clamp.Do you have them scratch off the paint to get a better bond?
They why I posted the question, if not dedicated the duplex could and most likely be used for somrthin else in the closet like a condensation pump or dehumidifier on the furnace?
I didn’t see it but the contractor says that there is a nail flange and flashing under the lath paper. He insists that an inspector told him to do it like this.. I assured him tha the previous inspector will return for the next inspection.No window flashing & window not nailed per manu. specs.
I’m going to offer a partial defense for that picture. It’s admittedly a stretch. Couple of years ago i was visiting my brother in Ark in the summer. Hot. Its was sunday afternoon and the ac started acting up, not cooling. We determined the problem was the fan on the condensing unit was not coming on, so we fastened a box fan to the outside of the unit to blow some air across the coils. That worked for the rest of the day, and he called for service on monday.This is amazing. I shared with fellow condo managers in the office this morning and we are cackling.
Clever, I guess, and one of the most absurd things I've seen.
This house is close to a million dollar property. I wonder if they got a deal on the HVAC.
I think, purely speculation, that one is the primary and the other is the secondary drain. Melt has not backed up to the roof yet, so no flow through the secondary drain.Post #3860
Why would one lambs tongue ice up and not the other? I can't say I've ever seen that!
And that is why the secondary drain shall discharge via a lambs tongue in an apparent location.I disagree on having the drain go through the slab to a direct connection. Roof maintenance is usually a low priority item, so when the drain leader clogs with leaves and trash you won’t know until the problem gets serious.
