There were corrections. Even with no corrections this contractor had no problem trying to use a rotten enclosure.Is it the rotten enclosure or that the backfed breaker isn't fastened or the re-identified green wire?
The plan is to convert this panel from a main panel to a sub-panel, hence the conduit with the fat wire to the 100 amp back-fed breakers. The contractor can't seem to understand why the inspector turned it down. His lament that it is existing and therefor off limits speaks volumes about the contractor.
The owner took out a permit. The lady that lives there sent me a few pictures of the work that was done by a friend of theirs. Right away I knew that the friend does mostly commercial work. I have not seen much of the work yet but I expect it to be tidy....and well...commercial not residential.
This so looks wrong yet they do it anyway.
Is it actually wrong, or does it just look wrong?
Condensate pump ... do you require a shut down float switch in case the pump fails?
The float switch will turn on the pump when condensate fill the reservoir. My question was ... if the pump fails is there anything to shut down the system? Or maybe I’m not clear on your answer.The secondary condensate drain has a float switch.
“Yes ma’am we have the lowest prices in town for solar systems, but the change orders are going to be whoppers”.Had they measured to the correct point there would be just under or over 60". But I don't measure from the wall so they lose six inches.
Isn't the meter box considered an outlet?
2014 NEC 680.22 (D) other outlets shall not be less then 10' from the inside walls of the pool
An outlet is where electricity will be “utilized” such as a receptacle or a light. The service has switching devices.
Just wondering if the meter socket isn't much different than a light bulb socket. Doesn't a electrical meter use electricity to work?
