Yes I did...as the owner was chewing me out because it took four months to get the battery.Did you fail the last one for not being accessible?
My bet is on blown insulation while they had the roof covering off.
Yup, my thoughts exactly...My bet is on blown insulation while they had the roof covering off.
When the inspector states that gas pipe can’t be under a slab or inside a home he has made two incorrect statements. The lowest common denominator is what we deal with and those statements might be taken as absolute. He should have stopped with, “A gas meter shall not be located indoors.” and included, “Obtain a plumbing permit to relocate the gas meter to the exterior.”What he says is correct. Maybe he knows it’s futile to dig too deep, so he scores what he was called to look at.
I guess that you missed this.He should have stopped with, “A gas meter shall not be located indoors
No apology needed…. I have plenty of bad days…I’m going back to work so I can look forward to more.I'm sorry. Having a bad day at work. I had a choice between covering up something i should not have done (a procedural item) by glossing over it, or telling the truth and admitting to getting out of sequence. They didn’t take it well.
The important thing is you told the truth about yourself and took responsibility for what you should not have done. A rare display of manhood and character in todays worldI'm sorry. Having a bad day at work. I had a choice between covering up something i should not have done (a procedural item) by glossing over it, or telling the truth and admitting to getting out of sequence. They didn’t take it well.
So far i have not been called on the carpet over this, if/when it happens that’s going to be my defense. I did B before A and fessed up ... i could have said i followed procedures, if someone had investigated they would have found the truth, and that would have been worse.The important thing is you told the truth about yourself and took responsibility for what you should not have done. A rare display of manhood and character in todays world
And usually makes the problem a lot worse.Lying about a mistake is worse than the mistake, kills all credibly
