It is a stuck drill bit.
The installation instructions call for the foam/glue to be painted due to exposure to UV light. I wonder about flammability. There was a time when I was tasked with approving solar racking installation instructions for LA County. This company's effort would not make the cut.Why is this a bad idea, providing the adhesive foam is compatible with the roofing material, stand off and has the sufficient uplift strength.
Lightning arresting system are use adhesive to attach the system to the roof, walk mats are done the same. Trim on cars used double side tape, we hang art on the wall with command strips.
I saw that and went looking for the details. I didn't find an answer as to what they were certified to other than UL2703 Safety. However there is a Miami-Dade Notice Of Approval so there is the assumption that a hurricane won't rip it off the building. The installation instructions are so scant on details that I would question whether there is a legitimate Listing or Certificate Of Compliance.
Shirley it voids the roof warranty.....Pretty sure roll roofing was not designed to hold anything down but itself.....The concept of gluing the array to a roof covering just seems wrong for many reasons.
The Solar Stack looks like it was installed on a modified bitumen roof with a granulated cap sheet. This or a fully adhered membrane roof should be able to take the uplift. I'd be concerned about an installation on a non-adhered system or a TPO roof that is only fastened at the seams.
Pg. 10 of the instructions says that roof tiles must be cut out to install the pedestals! I can imagine how many leaks that would cause.
How long is that roto hammer spline bit/"ground rod"?
Is the a/c disconnect too close to the pool?
No and neither is the condenser…three inches to spare. The window frames are vinyl.Is the a/c disconnect too close to the pool?
The solid #6 originates in a panel and hits the first ground rod:Is that a continuous GEC (grounding electrode conductor) system? Or two GEC using the one GE (grounding electrode)?
Trip hazard
Prefer acorn grounding clamp on that application.
"Sometimes that's the best you can get!"
Not all electricians are smart..... I can't imagine an electrician doing that
If you buy conduit from a major electrical supply house, does every piece have a bar code price tag?Not all electricians are smart....
NoIf you buy conduit from a major electrical supply house, does every piece have a bar code price tag?
But that's where the drawings showed them to be placed!Now that is hard to believe. I can't imagine an electrician doing that and certianly not the pipe-fitter.
