I’ve seen and failed that.I advise the electricians to put in an 8d nail and bend it over and see how the inspector likes that....
Should the expansion tank be vertical?The inspection waqs for a water heater changeout. The expansion tank is against the vent. I can't say for sure that the heat from the vent would have an effect on the expansion tank. I can say that there should be six inch separation....so I did.
It's been a while since I read installation instructions for an expansion tank. As I recall some were stricter than others but I'm pretty sure that any orientation is acceptable. I might be wrong about that but the truth is that the expansion tank is a waste of money.Should the expansion tank be vertical?
I find it hard to believe contractors are still using these. However I see they still cannot install them properly. 120 ft long building and every one was installed like this.
Worse yet, drywall screws.I was actually surprised they didn't use wood screws.
My first drafting job was for a pool company. I don't recall ever having to note where the electrical meter or panel was. The biggest issues the jurisdictions were worried about way back when was proximity to the property lines and the house.Nice pool.
Somebody is going to be disappointed. And don't you know they will say, "That's where the plans show the equipment." The implication will be that it is the fault of the Building Department for approving the plans.
You are correct. I never see that on a plan. I convinced the last County office that I worked in to require the plans to show where overhead utility service drops came on to the property. You could get some idea of where the panel was located.My first drafting job was for a pool company. I don't recall ever having to note where the electrical meter or panel was. The biggest issues the jurisdictions were worried about way back when was proximity to the property lines and the house.
Is it still a violation if they didn’t tighten the clamp screws?The cluster of cable in the single clamp is a code violation.
With that panel design and a large number of cables entering it, there is no other way except a large Romex® connector to bring them in, they could have at least snugged it up instead of leaving it loose. That is one of the weak points of the meter main panels like that, rather then the East Coast style of the meter can outside & the panel inside.The cluster of cable in the single clamp is a code violation.
