That’s not fascia, that’s aluminum cladding. Surely you’re not doubting that Bubba has a gap under the fascia board.That is about as ugly as I've ever seen a cut valley. The Gable fascia board should be about an inch short of landing on the shingle with some wall to roof flashing behind it.
And is that a line of caulk along the edge of the shingles in the valley?That is about as ugly as I've ever seen a cut valley. The Gable fascia board should be about an inch short of landing on the shingle with some wall to roof flashing behind it.
It's hard to be 100% sure what is happening in the photo, but I find the photo consistent with the idea that the install matches your diagram, except the trimming of the shingles on the right hand plane is very rough (or else covered with a line of roofing cement), and an inch or two back from the valley center line.It looks like a closed cut valley done bass-ackwards.
Education is expensive and I suspect, they are in for a whole lot of it."We don't need a contractor, we can do this ourselves."
That was a 2019 file I stumbled across while archiving. There were ... costs .... involved in rectifying the issue.Education is expensive and I suspect, they are in for a whole lot of it.
That is pretty sweet. Aside from the scabs, what are the bottom ends of the rafters doing?"We don't need a contractor, we can do this ourselves."
It might work if they can get a purlin underneath it."We don't need a contractor, we can do this ourselves."
No question it can work. You're a professional who knew how to make it work.It actually can work if you get enough nails in it, probably a dozen or so on each side. I scabbed extension rafters to the original when I raised the roof and finished a bedroom in the attic of our former house. I calculated the number of nails necessary to transfer the bending stress. It held up for the 25 years we were in the house and through several snows.
I have approved many a scab.....picked on a few too..... there is a minimum of 4' on each side of the break for a total of eight feet and plenty of nails. That has always been for a repair or one questionable rafter but I wouldn't aprove that in new construction without an engineered, stamped detail.It actually can work if you get enough nails in it, probably a dozen or so on each side.
IIRC, the solution was a "dwarf wall" to support the splices. That's an acceptable solution in Canadian Codes.I have approved many a scab.....picked on a few too..... there is a minimum of 4' on each side of the break for a total of eight feet and plenty of nails. That has always been for a repair or one questionable rafter but I wouldn't aprove that in new construction without an engineered, stamped detail.
What are we looking at here?It ain't often that I am at a loss for words.
Combustible vent pipe of some nature that goes through a one-hour fire separation. They done squirted some-a that-thar red fire caulking around the outside and called it good.What are we looking at here?
"Th' little writin' on the tube of guck we got said it was good fer four hours. Whachoo gettin' all worked up about?"They must be some real pros to find a listing for a fire stopping system that deals with plastic ductwork.
