I see diagonal bracing let into the studs, is this in addition to plywood sheathing because of seismic?The scope of work is remove wall finish down to studs, insulation, plywood sheathing and lap siding. The insulation is installed inside out.
I think that the plywood is two things: 1. It will help provide a smooth, straight base for the Hardi-Plank. 2. The result of an ambitious salesman. Oops, salesman is not a word. Salesperson implies human form and that isn't much better. So allow me to change the wording to "entity that sells".I see diagonal bracing let into the studs, is this in addition to plywood sheathing because of seismic?
Don't you want the vapor retarder on the exterior in most of CA?The scope of work is remove wall finish down to studs, insulation, plywood sheathing and lap siding. The insulation is installed inside out.
I can’t speak for most of California but here in southern Ca. The vapor retarder faces the conditioned space.Don't you want the vapor retarder on the exterior in most of CA?
Climate Zone 3? It doesn't matter where you put the vapor retarder, probably better to not include it in the assembly at all. But if I were to add it, it would be most useful on the exterior IMO.I can’t speak for most of California but here in southern Ca. The vapor retarder faces the conditioned space.
Somehow I don't think that's plastic.Looks like plastic pipe. They need a plastic ground connector.
There’s another rod twenty feet from this one.I see only 1ground rod, do you have the results verifying that there is 25 Ohms of resistance or less? If not they need another rod to be driven.
The only thing you can say is that the contractor at least realized that bonding was Req!We require a jumper between the cold, hot and gas pipes. But not like this.
