steveray
Seismic Redwood?
No we don't have that. At least I haven't found that.steveray said:ICE....You guys don't have the 2" up and 2" down on the nail plating at the top and bottom of wall? (IPC)
What's worse is that the structural insulation foam is not an approved fireblock material.mmmarvel said:Whadda mean they torn up the shear wall??? Looks like structural insulation foam to me.
the grate stuff foam we have here come in 2 color; natural and orange, the if you read the can they have the same ratings and the natural color is $2.00 a can cheaper.ICE said:What's worse is that the structural insulation foam is not an approved fireblock material.
Yeah, but the fiberglass insulation they are going to use is.....7. Batts or blankets of mineral wool or glass fiber or other approved materials installed in such a manner as to be securely retained in place.ICE said:What's worse is that the structural insulation foam is not an approved fireblock material.
I think they are probably going to find out! What the heck have they been coring?ICE said:I wonder how much is too much for a roll-off truck to pick up.https://flic.kr/p/nUiUiy [/URL]
Firestop vs Fireblock Expanding Foams, Flame / Burn Test ... check this video out that was sent to me about the fire block or orange foam. We use to allow it at a fire block but not no longer, however they can use at a draft stop only.ICE said:I have seen yellow and orange foam. I look for the word fireblock on the can. The yellow continues to burn when the source of a flame is removed. The orange shrinks away when subjected to a flame but will not burn like the yellow does. I wanted to reject them both but I was told that I must accept the orange because it is listed as a fireblock.
Ya those meds are strong stuff...eat them for too long and I feel stuffed.Moscow said:Firestop vs Fireblock Expanding Foams, Flame / Burn Test ... check this video out that was sent to me about the fire block or orange foam. We use to allow it at a fire block but not no longer, however they can use at a draft stop only.
