Oh Well
And outdoors. The owner said that he would cover the washer and dryer with a tarp when it's raining.TheCommish said:with the washing machine in the way
He was lost after his first cup of coffee, waaay before the pitch change.ICE said:Look at the rafter in his hand. The roof changed pitch and he is lost. There is a couple pallets of roof tile in the front yard.
It is held up by the ridge....nothing else
The evaluation report (ICC ESR or IAPMO ER) for post bases often times specify a minimum concrete cover. What do the engineered plans show?ICE said:It's a commercial building. There will be a post supporting a center beam of a flat roof. I was there for a slab inspection. The engineer blessed the work during a structural observation. The contractor was there for my inspection. I said "Oh my gosh, that looks weak" The contractor didn't hesitate and said "Oh my gosh, your right"
The plans show the same post base turned 90 degrees. I don't think that would be an improvement. The entire anchor is in the concrete stem which could easily be snapped off. Simpson allows some radically small edge distances but probably not on both sides. I didn't bother to look at that since the issue is the stem. Not to mention that an inspector approved it and the engineer did too.Phil said:The evaluation report (ICC ESR or IAPMO ER) for post bases often times specify a minimum concrete cover. What do the engineered plans show?
I woulds like to see if he can frame a hip roofICE said:http://www.flickr.com/photos/97859466@N05/10565596704/ [/URL]
http://www.flickr.com/photos/97859466@N05/10565815363/
http://www.flickr.com/photos/97859466@N05/10565546246/
I do not understand?ICE said:When I told them that there can't be exposed Romex...
We don't allow exposed NMC. Their solution is to drywall the garage, including the lid.Glenn said:I do not understand?
nonmetallic jacket.Otherwise known as Romex which is a trade name.334.2 Definitions.Nonmetallic-Sheathed Cable. A factory assembly of two or more insulated conductors enclosed within an overall
